Is it worth changing the beolab 8000 to 8002?
What is the main difference?
I heard the 8002 is wireless is this the fact and is that advantageous compared to 8000?
Thanks.
Beolab 8002 is in no way a wireless speaker. The only difference known for sure is that B&O updated the amplifier section to ICEpower.
Regards
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Personally I wouldn't bother... Add a Beolab 2 to them instead!
x:________________________
The advantages of the 8002 is that it will use less power and is cheaper to produce. B&O have themselves stated that the sound quality is unaltered. Regard them as a way for B&O to rationalise their amplifier production.
Peter
another differance is if you are going to setup a Beonet down the road you will not need to add coils to the speaker lines.
BeoSystem 5500, BeoVision 10-46, BeoLab 8002Apple TVSamsung BD-D7500Wii
