hello people.
Need help on converting a beomaster 5000 type 2322 (240V) main transformer. Here in Canada, my house outlets are 120 V , i can convert the existing transformer down to 130V or 110V. My question to you is... should i convert to 110V or 130V ,and what fuse do i use ??your input would be greatly appreciated.
go for 130V and upper the fuse by X 1.8
gracias.
