My BV11-46 is installed yesterday, now i noticed some dust between the glass.
Is this normall or is this not acceptable?
For me, if you can see dust behind the glass, then that is not acceptable particular if it is clearly visible.
Regards Keith....
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
I wouldn't accept dust behind the screen on any TV I'd bought... even if it was £99.
Modern manufacturing processes can create environments clean enough to prevent dust - so why can't B&O?
I absolutely would not accept this. Bang & Olufsen is a premium brand which you pay a premium price for. Do not accept anything less than a premium product.
Lee
Past five years I bought a "Loewe TV" (German factory) with a contrast filter panel infront of the LCD Screen.
Many dust between the glass and the panel.
The seller means that's not normal, the tv was complaining at the Loewe factory.
The answer from an Loewe engineer: this is normal, this is not a complaint reason.
I said: sorry no problem, doesn't matter, I like to pay 4500,00 euros for a dust catcher.
That's my experience , not only B&O has this problem.
I would not buy again such an expensive tv, I have learned from it.
Ingo
BeoVision Eclipse 55“ wallmounted, BeoRemote One BT; BeoSound 9000(ex-weiss), BeoLab 9; BeoLab 8000 rot; Beosound 1 grün; BeoPlay H6; Beo4
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
My dealer is going to remove the dust between the glass plates
My 8year old panasonic plasma has never had dust in the panel. If it had it would be a DOA and sent back. You don't spend more money on less quality.
koning:My dealer is going to remove the dust between the glass plates
Martin:My 8year old panasonic plasma has never had dust in the panel. If it had it would be a DOA and sent back. You don't spend more money on less quality.
BeoGreg:And to be perfectly clear, it's not because I got used to it and I'm totally fed up of complaining that I accept it. Yes it's unacceptable for a premium product like a Beovision (and for any product by the way). The excuse I give for B&O is that it's some kind of "handmade" product and such thing happens. One day when I was taking delivery of a red italian car with a horse on it, I was looking at an other new car at the dealership that had a little paint-run on the front bumper. Unthinkable ! I'm a watch collector and specks of dust under the crystal are more than common. My brand new in AD Rolex GMT BLNR two years ago a white speck on the dial. Made it removed. My brand new in AD Rolex Explorer II white dial last week a orange speck under crystal and a tiny black speck on dial + black hands badly painted on sides. Unthinkable but I leave it like that, it's only with a severe inspection that you see it and my eyes are getting already tired (I'm 45). So if you only see your dust under contrast screen with a powerful led light : just try to forget it ! And please post a pic of your new toy and tell us what you think about it compared to BV10.
i'm getting a new one.....Problem Solved
koning:i'm getting a new one.....Problem Solved
the tv is sealed for dust,why do you say it isn't sealed?
koning: the tv is sealed for dust,why do you say it isn't sealed?
Because of my experience,
dust particles come still with time between the glass and the screen.
You can even notice it if you visit some showrooms... If you look carefully you will find quite often some particules of dust inside many display Beovision...
oke',
but there must be some limits i think
