connecting beovision 10 to apple tv
This post has 17 Replies | 2 Followers
malcolm welborn
canary islands
Posts 188
malcolm welborn Posted: Fri, Jul 13 2012 10:51 AM
i am in the process of buying an apple tv tp play films from i tunes or my ipad through my beovision 10, my question is do i have to buy the composite av cableas well to do this, or can i get the cable from elswhere. may play some music as well.
malcolm
Paul W
London
Posts 1,810
Paul W replied on Fri, Jul 13 2012 11:40 AM
I Malcolm, just an HMDI lead should be perfect! I know that there can be a HUGE debate over cables, put i'm a HUGE fan of QED!
Please report back on your experience with the Apple TV box. What a superb purchase and what a stylish, timeless piece of art your television is!
malcolm welborn
canary islands
Posts 188
i will report back paul will get my dealer  to install and he can get me the cable apples price of £30 seems high, will also configure my beo4 and beo5
cheers
malcolm
Paul W
London
Posts 1,810
Paul W replied on Fri, Jul 13 2012 12:41 PM
Excellent Malcolm! A good lead should last a lifetime and remember it's a 6.5K upwards piece of art so I guess £30 isn't too bad :)  But yes a top quality QED is around that price! I was streaming a HD music app VEVO from my iPhone 4s to a friend's Apple TV the other evening and WOW what amazing quality!!!!!!!!!! I LOVED IT!
elephant
AU
Posts 8,219
elephant replied on Fri, Jul 13 2012 1:13 PM
malcolm welborn:
I like the Apple cable because it is thinner than more expensive ones.
So I have two Apple HDMIs, a Belkin HDMI that is thicker, and an expensive rush emergency purchase that has a braided sleeve.
I see no difference between the various images presented by these various cables - so for me ease of running the cabe is the discerning characteristic
BeoNut since '75
malcolm welborn
canary islands
Posts 188
hi there seems a long time since our denmark visit  good time had by all.
further question see apple has two cables  a composite av cable, or if you have a new tv you can use component av cable
which one for beovision 10?? good to tell im not a tech guy lol
malcolm
KingOfSnake
Posts 162
I used to buy QED Cables - now I buy from Steve @ Sounds Heavenly, really not necessary to buy QED cables and spend all the extra unless you like the colours of the cable sleeves IMHO.
2012martin
Posts 202
Hello Malcolm all you need to connect your apple tv to your bv10 is 1 hdmi lead. Then you wirelessly stream from your iPad or I phone to you apple tv. I'm assuming the cable you mean which is £30 from apple is the av cable which goes from the I pad direct into your bv10. You will not need this, this would be used if you didn't have apple tv but you would then be restricted by the cable length.
Ps. You need wifi to connect to your apple tv.
Hope this helps
elephant
AU
Posts 8,219
elephant replied on Sat, Jul 14 2012 3:43 AM
malcolm welborn:
sadly it now feels like ancient history even though it was only 7-ish weeks ago
malcolm welborn:
sorry I missed the "composite" part of your original question !
so this begs the question of which Apple TV you are buying ?
there are two basic types:
So which you choose will depend on which connectors you have free on your BV10; but I would recommend the latter/later style.
Then you can connect wirelessly your iPad to the ATV and broadcast the music and videos from your iPad; or use the remote to command the ATV to access the internet for content.
If you add a PUC to the ATV (I sticky tape mine to the front of the black puck) you then can control the ATV via a Beo4 rather than the silver Apple remote that comes with that series of ATVs.
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Sat, Jul 14 2012 4:04 AM
2012martin:
strictly speaking you can attach an ethernet cable to the ATV and wire it to a router - or use wifi.
it is the iPad that needs wifi to connect to the ATV and its router.
I think Malcolm has been thinking of directly connecting his iPad to the BV10 using AV cables, which is not strictly necessary
http://en.wikipedia.org/wiki/IPad_accessories
here is part of my set-up to illustrate ... shows black hockey-puck ATV (g2), the ATV's menu on our BV8-32 (white) and the three cables needed - from top to bottom: power, PUC, HDMI
BeoNut since '75
2012martin
Posts 202
There's also a way of controlling your apple tv direct with the beo4 or any remote you like without the need for a ir blaster. You will have to program it though. I haven't tried this but it seems fairly straight forward. Here's the link
http://support.apple.com/kb/HT3296
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Jul 14 2012 9:40 PM
That doesn't work, because ATV can't receive the IR codes of Beo 4!
2012martin
Posts 202
Ok raeuber. Like I said a I haven't tried. Thanks for letting me know. I only knew this because I have read it on hear. Like  I said I haven't personally tried. Have you tried? How about with a beo5?
Thanks again
Paul W
London
Posts 1,810
Paul W replied on Sun, Jul 15 2012 2:43 PM
I notice that the Apple HDMI lead is £15 on the Appe site - Extremely good value.
You can of curse control your Apple TV with either the iPhone or iPad app. Very Very nice app that is incredibly easy to use!
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Jul 15 2012 3:47 PM
2012martin:
Thanks again
The ATV is able to learn the commands from other remotes than the original Apple remote. But this doesn't work with B&O remotes, neither Beo 4 nor Beo 5/6. But the Beo 5/6 can be programmed with the original Apple TV codes.
So the PUC solution is in my eyes the best and easiest solution to control an ATV with a Beo 4/5/6.
/Räuber
OKF
Posts 33
OKF replied on Sun, Jul 15 2012 5:44 PM
.....which means you should use the IR Blaster
OKF
Posts 33
2012martin
Posts 202
2012martin replied on Sun, Jul 15 2012 10:50 PM
Ok thanks for reply
Page 1 of 1 (18 items) | RSS
