I have a BV7-55 that has not been updated for several years. It has Beolab 9s as a possible speaker. It does not however have Beolab 12-3 which are my rear speakers, or Beolab 20 which I have ordered to replace my 9s in front.
Is there a software update for the BV7-55 that would add the 12-3s and 20s to the menu?
And if not, which speaker would be the best selection for the 20s? 9s perhaps?
Thanks!
edit
Got the answer. Dealer provided me with a document on speakers. For older TVs the proper setting for 20s is Beolab 5 with a 3 step volume gain. Also learned from it that my BL 12-3s should be set as Beolab 3s and 1.5 meters added to distance to account for different processing times of older compared to newer speakers when used with a BV7.
Got the answer. Dealer provided me with a document on speakers. For older TVs the proper setting for 20s is Beolab 5 with a 3 step volume gain. Also learned from it that my BL 12-3s should be set as Beolab 3s and 1.5 meters added to distance to account for different processing times of older compared to newer speaker.
BeoNut since '75
Glad you found all the info you needed Raz :)
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
BAND'OH!:Glad you found all the info you needed Raz :)
