Hi guys
Is it possible to use beo1 bluetooth remote to control lg c9 and core ?
In case you mean a BROne/bt - a beo1 is a different remote - yes to the Core, no to the LG.
Hey mm
Yes that's what I meant thanks for the prompt reply, i thought it might as its bluetooth.
