List of Beo4/BeoRemote One IR commands?
lundmark
Stockholm, Sweden
Posts 105
lundmark Posted: Sun, Nov 5 2017 3:01 PM
I'm looking for a list of all available commands that can be sent with a Beo4 or BeoRemote One. Hex codes would be great too (or whatever format B&O uses).
This is for use with the NEEO universal remote control, which currently doesn't control Beovisions very well at all. I'm trying to beta test for them and need your help to find out the right commands for them to add into the driver database. More info about that here: https://planet.neeo.com/t/k9kg9z
Hansp
Posts 12
Hansp replied on Sun, Nov 5 2017 4:06 PM
A  lot of what you are looking for is at the link below:
http://www.hifi-remote.com/forums/viewtopic.php?t=12486&postdays=0&postorder=asc&&start=0
Hansp
Posts 12
Hansp replied on Sun, Nov 5 2017 10:14 PM
Hi again,
Also in this official document:
http://mlgw.bang-olufsen.dk/source/documents/mlgw_2.24b/MlgwProto0240.pdf
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Sun, Nov 5 2017 10:34 PM
Thanks so much! I'm sure that will be very helpful
lundmark
Stockholm, Sweden
Posts 105
I'm having issues with controlling the TV's own menus when emulating the Beo4 with the universal remote. The cursor buttons control whatever is connected to the Beovision's IR blaster (PUC).
I suspect the way it works on the Beo4 is that when MENU is pressed, another set of commands are loaded onto the joystick for controlling the TV menus. Is this correct? If so, I need a different set of navigation commands than the one currently in NEEO's database.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
