i got a beolab transmitter so i could have speakers in a different room. however, it seems that it the signal strength is insufficient as it drops out when i move the speakers into the room. it is only about 40 ft. does anyone happen to know of a way to increase the WISA signal strength? a network expander is not the correct bandwidth.
johnbrks:i got a beosound transmitter so i could have speakers in a different room.
thanks. so one must wire the room to get multi-room sound wirelessly?
sorry. meant beolab. so it means each room must be wired in order to get wireless sound? the b&o website illustrates the wireless sound differently and talks about having sound in different rooms. perhaps they neglected mention of the need to wire a transmitter in room?
You got me confused...
Beolab transmitter is not for multi-room sound.It is just for getting you sound to your wireless speakers (or to Beolab receiver + non-wireless Beolab speakers).
Please show the link talking about Beolab transmitter AND sound in different roosm.
Ralf
For example, on the beosound essence page (http://www.bang-olufsen.com/en/sound/sound-systems/beosound-essence) the statement is made that the essence is ready for Beolink multi room. Granted Beolink multi room is never really defined, but the page says 'BeoSound Essence is an integrated component in the BeoLink Multiroom experience. Play different music in different rooms or let the same music flow throughout your home. Control the flow simply by touching your BeoSound Essence.'. Now, as nearly as I can tell the essence is a remote that connects to a receiver via Bluetooth. There is no mention of how one gets sound going to different rooms.
finally, this page seems to imply it is wireless. http://www.bang-olufsen.com/en/beolink-multiroom True, the page is devoid of specifics, but it is unclear how one would connect a beosound moment to speakers in another room using wires.
BeoNut since '75
johnbrks:For example, on the beosound essence page (http://www.bang-olufsen.com/en/sound/sound-systems/beosound-essence) the statement is made that the essence is ready for Beolink multi room. Granted Beolink multi room is never really defined, but the page says ' BeoSound Essence is an integrated component in the BeoLink Multiroom experience. Play different music in different rooms or let the same music flow throughout your home. Control the flow simply by touching your BeoSound Essence.'. Now, as nearly as I can tell the essence is a remote that connects to a receiver via Bluetooth. There is no mention of how one gets sound going to different rooms. finally, this page seems to imply it is wireless. http://www.bang-olufsen.com/en/beolink-multiroom True, the page is devoid of specifics, but it is unclear how one would connect a beosound moment to speakers in another room using wires.
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Thanks. That's helpful. I guess I don't fully understand b&o's setup. I have a Samsung tv, a receiver, a beosound moment, and transmitter 1 with Beolab 18’s in my den. That works fine. I got 2 wireless receivers for my Beolab 3’s and want them in the living room. I'd like to play music from the moment in the living room as a separate zone. I'd like to keep the lab 3 speakers but The transmitter 1 doesn't reach to the living room (though it should by distance). I'm not clear how to do this.
johnbrks:Thanks. That's helpful. I guess I don't fully understand b&o's setup. I have a Samsung tv, a receiver, a beosound moment, and transmitter 1 with Beolab 18’s in my den. That works fine. I got 2 wireless receivers for my Beolab 3’s and want them in the living room. I'd like to play music from the moment in the living room as a separate zone. I'd like to keep the lab 3 speakers but The transmitter 1 doesn't reach to the living room (though it should by distance). I'm not clear how to do this.
