Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
The A1 and a half ;-)
Or the A2 minus a half ;-))
No not heard of that.
Personally I'd say, you would need that?
But you never know these days.
Sandyb:No, though on a slightly related note, speaking to my dealer yesterday, he understands the new OLEDs to be 65 inches, and potentially above, and not expecting any size overlap with the existing TVs (I.e no 55 inch OLED)......not sure how everyone is going to react to that, though doesn't bother me too much
yep, hadn't thought about it beforehand, but makes sense......supposed to be a 65 and a larger size(s) for the OLEDs......
Hiort:Heard that a smaller version of A2 is coming, with aluminum grille. Sits between A1 and A2 in the lineup. Aggressive price. Anyone can confirm?
That wouldn't make much sense? The A1 isn't *that* much smaller than the A2, plus how 'aggressive' can it be? A2 is decent value at £299.
Sandyb: yep, hadn't thought about it beforehand, but makes sense......supposed to be a 65 and a larger size(s) for the OLEDs......
Sorry - because this is off-topic.
The new LG/BV's are rumoured to be built on the E-series from LG.
These are available in 55 and 65".
So nothing above 65" on the horizon (pun unintended ;-))
good point, my bad.....was only passing on what my dealers impression was.......how they resolve any potential overall between existing TV ranges and the new OLED they issue, is anyones guess......but yes the E series is only 55 and 65.......
Probably the Beoplay P2...
https://fccid.io/TTUBEOPLAYP2
https://fccid.io/document.php?id=3242569
benoit:https://fccid.io/document.php?id=3242569
anymore suprices this year?
Hiort: benoit: https://fccid.io/document.php?id=3242569 Yep. P2 is the name. Price around 150 euro according to my source.
Do you know when it will be launched?
Concerning launch... The confidential-letter states 180days as of begin Januari... So.. some months patience :-)
Karel.
kuyttendaele: ...180days as of begin Januari...
That would be the first of April ;-)
Millemissen:That would be the first of April ;-) MM There is a tv - and there is a BV.
This one may be perfect to put in a small suitcase for the summer vacations...
benoit:This one may be perfect to put in a small suitcase for the summer vacations...
If it is even smaller yes... And as the rumored price is lower (150€) and according to the label measurements, I think it must be smaller.
Maybe 13x8 cm if I calculated well.
I think even smaller ;-)
