Does anyone know what size bolts the beovison 7-32 takes to fix to the motorised floor stand?
thanks
Toby
Hi
M5x20
Thanks for your reply.
I have loads. Want new to send you some?
Lee
That would be great.
Posted!
Once again you are a star Lee.
Thanks for that looing forward to getting my BV7-32 set up in my new extension, will post pictures when up.
Thanks.
