Avant Join Command
This post has 13 Replies | 0 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Wed, Jul 13 2016 11:58 AM
Hi
I have linked my Avant with the A9 and the A6
Does anyone know how I can send the sound to either the A9 or the a6 using the Beo Remote
Say I'm sitting on the couch and I want to send the sound to another room
I can't figure it out using the remote on the avant
Thanks in advance.
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 14 2016 3:33 AM
Maybe you have to use the App ?
Or be in the room ...
After all it's a network equals !
BeoNut since '75
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jul 14 2016 7:46 AM
elephant:
Correct, use the Beomusic App.
Start the app. Tap the 2 rectangles. Tap box of the Avant, the box becomes the source with the focus. Tap the + signs in the boxes of the A9 and A6.
(If setup correctly) both will start playing the source of the Avant (as can be seen in all 3 boxes; the same source is shown)
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks I'll try the app
I was trying to use the remote - so perhaps it can't be done.
I see there is an option of "join" but whatever that means is a mystery
To the app I go WhistleBig Smile
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jul 14 2016 8:04 AM
if f.e. the A6 plays, you can choose the JOIN command to the Avant. It will starts playing the source of the A6 on the Avant
if in a Netlink more sources are active, with repeatedly selecting JOIN on the remote, all the active sources will be audible one after the other on the Avant
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 14 2016 11:02 AM
Or if the Avant is playing walk to the other room and say you want to join the network ie Avant
BeoNut since '75
Beroli
Germany
Posts 316
Beroli replied on Thu, Jul 14 2016 11:53 AM
when I listen to a Source in my Study over my Essence Mk2 and I press the join button on the BeoRemote One for the Avant, the Avant "plays" the same source like on my Essence. Works perfectly. Just Add join on the Beoremote and make sure that the NL-Devices are listed in the NL-settings of your Avant.
Cheers Beroli
Beroli
Germany
Posts 316
Oh it seems that I misunderstood you. You are trying to send to A6 not from. Therefore forget what I wrote.
Millemissen
Flensborg, Denmark
Posts 14,680
You can't (Beo)remote control the A6.
You'll have to do that manually or using the app or using the 'wheely'.
You can 'join-in' on the Avant, but only on 'joinable' sources - e.g. not on airplayed content or on Spotify Connect.....
If you have configured the ('joinable') sources of the A6 as connected sources on the Avant, you can also start these with the Beoremote alternatively using the source menu of the tv.
If configured, you can also choose a source from the Avant using the app - e.g. listening to a cd, that is playing in a BRP, that you have connected via HDMI on the Avant.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jul 14 2016 1:10 PM
Beroli:
Cheers Beroli
The listing in the NL-settings of the Avant is not necessary.
If a NL source plays (no Spotify/Airplay though) it can be activated with JOIN.
Strange enough one can JOIN Spotify between the Essence mkII, BS35, A6.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jul 14 2016 1:21 PM
Millemissen:
Almost ALL NL sources (not Spotify connect/Airplay) can be started on the Avant (even if not configured; they must be active though) by the JOIN command.
Millemissen
Flensborg, Denmark
Posts 14,680
@Corolpa
That is exactly, what I wrote.
@Beroli
That is because they all have support for Spotify Connect - the Avant hasn't.
Beroli
Germany
Posts 316
Beroli replied on Thu, Jul 14 2016 4:06 PM
Millemissen:
@Corolpa
@Beroli
Hi MM,
very confusing, I never wrote anything about spotify. Therefore I don't know what you are trying to tell me. I merely wrote that the Join-Button on the remote works perfect for me. After writing the comment, I recognized, that this wasn't the question. Maybe we booth should read the thread more carefully.
Cheers Beroli
Millemissen
Flensborg, Denmark
Posts 14,680
Sorry beroli ;-(
That was in the post from Carolpa as well.
Page 1 of 1 (14 items) | RSS
