In the test module TM 27 writes 1 IOP 19 (TP module HW error APOS).What should I do?
Is the BS 300 working?or you already fixed an issue?? I think I am also had a same error once. TM 27 writes 1 IOP 19 (TP module HW error APOS).
If your Beosound responds to option programming and the load button, but nothing else (no respons on keyboard instructions of Beo4 commands), then you have a shot microprocessorboard. Which aren't available anymore......
(I can still can fix these)
Hi Beobuddy,
I have a same error message on my Beosound 3200. How you can fix that?
19: TP module HW error APOS My BS 3200 not responding. only load button works.
Can you fix that?
