Beolab 8000 woofers
marexy
Posts 710
marexy Posted: Wed, Feb 17 2016 8:37 PM
Please help.
I need specifications of Beolab 8000 MK1  -mid/bass speaker drivers.
dimensions...ohm..sesitivity...W..?
Can ayone help.
I need to find replacement for them.
Thx :)
marexy
Posts 710
marexy replied on Thu, Feb 18 2016 3:37 PM
It is possible to find it on web ?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Feb 18 2016 5:42 PM
The short answer, I'm afraid, would be no.
B&O rarely disclose the T/S parameters for their speaker drivers.
Most drivers are custom produced to B&Os specs and it's practically impossible to
find matching replacement drivers anywhere else.
It has been like this for decades and I doubt it will ever change.
If you need a woofer, ask your B&O dealer - or find a similar speaker to donate one.
In the case of Beolab 8000 I would expect B&O to still be able to supply the correct part.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Feb 18 2016 6:08 PM
The woofers from the earliest mk1 with the small dome aren't available. These are replaced with the ones with the bigger flat dome in the middle.
marexy
Posts 710
marexy replied on Wed, Aug 3 2016 6:22 AM
I solved situation.
I used the speakers of similar dimensions and power.
It works great.
Page 1 of 1 (5 items) | RSS
