Beolab 4000 in the shelf: Heat problems?
This post has 2 Replies | 2 Followers
TWG
Posts 1,672
TWG Posted: Fri, Jul 29 2016 6:56 AM
Hello,
I'm thinking of placing some Beolab 4000 or a Beolab 2000 inside a book shelf. Could this lead to heat problems of the speakers or is it possible without problems? Do you have experience with it?
leosgonewild
Helsinki, Finland
Posts 2,373
I have not experienced any heat at all with the 3 pairs I have had. It dispenses heat pretty good from the massive radiator on the back. Never felt it get warm.
But then again, we might have different opinions of what a bookshelf is Big Smile
I would build it in between books. Some air is needed I guess.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi TWG,
I would go for the mk.2 (2008 on) Beolab 4000s with the digital ICE Power amps - these run much cooler than the mk.1 4000s or 2500s, which have class AB analogue power amps inside.
I would also agree with Leo that some air around the speakers is always a good idea for cooling!
If you need any help with cables to get everything connected, please feel free to ask Cool
Kind regards, Steve
Steve.
www.soundsheavenly.com
Page 1 of 1 (3 items) | RSS
