Hi there,
I was wondering if there is a way as a user to check what the software /firmeware version of my Beolab 18 is ?
And is there a list to see what kind of releases this or last year have been ?
I think this is done wirelessly via WISA if they are connected to either a compatible Beovision or Transmitter one. There is a manual update you can force to the Transmitter one that will update speakers if updates are available.http://bogo.custhelp.com/app/answers/detail/a_id/10236/~/how-do-i-update-the-software-of-my-bang-%26-olufsen-wireless-loudspeakers-using
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
From what I understand is that only the Beovision is updated trough internet, but not the Beolab 18 ?My dealer did one last year manual with usb connection laption-BL18.
Does anyone know if the 5 Ghz problem with Apple Extreme and WISA already is solved ?
But what I also would like to know is, where can I check what the last update is ? Or the list from previous updates ?
Here is a link that mentions and appears to have the software download for speakers.
http://www.bang-olufsen.com/en/product-support/accessories/beolab-transmitter-1
I just tried the link to make sure it was working. On my phone it took me to a V1 page. On my computer it works. The page is the Transmitter 1 support page.
Razlaw:I just tried the link to make sure it was working. On my phone it took me to a V1 page. On my computer it works. The page is the Transmitter 1 support page.
Duels: Razlaw: I just tried the link to make sure it was working. On my phone it took me to a V1 page. On my computer it works. The page is the Transmitter 1 support page. What does updating them actually do?
I don't know what the updates might do. I did try the download. It appeared to me that the last updates were in 2014. As My Beolab 20s are less than two months old, I assume they have the latest software version so I did not go any farther than the initial download.
