Beogram 2202
BillNieder
Posts 12
BillNieder Posted: Fri, Jul 31 2020 8:19 AM
I recently bought a Beogram 2202 record player. It works fine so far except one problem. When I hit the "pause"-button the tonearm lifts and the  platter stops turning as it should. However the tonearm is not fixed in its position but starts drifting in direction start posiition. It looks like the arm is pulled by the antiskating spring. Any idea how to solve the problem?
Hartmut
mrlimbo
Posts 9
mrlimbo replied on Fri, Jul 31 2020 10:15 AM
I assume you've ruled out the simple solutions, deck level, arm balanced correctly and the correct vtf set!
BillNieder
Posts 12
BillNieder replied on Fri, Jul 31 2020 10:51 AM
Yes, I did. In addtion to my previous description of the problem: starting a 30cm record the arm finds the correct cue-position, lowers and starts playing. Starting a 17cm record the arm finds the correct cue-position,but during lowering it drifts away.
BillNieder
Posts 12
BillNieder replied on Fri, Jul 31 2020 12:15 PM
Thanks, you put me on the right way. I just increased the stylus pressure - now everything is working well. Previously I balanced the arm and adjusted the pressure to 1,5p. But that was obviously to low for the MMC 20S in use.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jul 31 2020 1:19 PM
Check the calibration of the tracking force setting.
Page 1 of 1 (5 items) | RSS
