I just got a weird feedback from B&O support team...it looks like you can turn your BL5 on/off, adjust volume, adjust balance and even set Option to 0, 1 and 4 using Beoremote One BUT you can't set the line input level!
That can only be performed using Beo4...
Does anyone know if this is true? For me this seems to be impossible! B&O would never be this stupid, right???
Putzgrilous:Hi, I just got a weird feedback from B&O support team...it looks like you can turn your BL5 on/off, adjust volume, adjust balance and even set Option to 0, 1 and 4 using Beoremote One BUT you can't set the line input level! That can only be performed using Beo4... Does anyone know if this is true? For me this seems to be impossible! B&O would never be this stupid, right???
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I have BL5s connected to a Playmaker. I cannot seem to pair them. I also have an A9 gen 1. I would like to use it for both. Can someone help? All the things they said online, I couldn't find on the remote.
