beovision 7 mk1 40" can not conncect PC to TV using DVI-i to VGA, im using AV 4 as a source, dos not register on remote as PC when i press list... please help...!!!
wolfie2402:dos not register on remote as PC when i press list... please help...!!!
You need to ADD the PC command to the active commands BEFORE they show up when pressing list!
Check the BEO4 User manual!
If you have a Beolink 1000 you can simply press SHIFT + STORE (PC)
