Beoplay H5 with custom moulded Snugs tips
Chrisbriton
Posts 2
Chrisbriton Posted: Sat, Aug 20 2016 2:09 PM
Hi All,
I've been relying on isolating bluetooth earbuds for work to block out ambient machine noise, with the adden bonus of music and podcasts to keep me sane.
Really like the look of the Beoplay H'5 but concerned about reviews of them falling out of the ears while moving. Has anyone tried using a custom moulded tip with the h5's like these snugs?
https://snugsearphones.co.uk/product/snugs-only/
Hoping they might eliminate any fitting problems.
Roy
The Netherlands
Posts 37
Roy replied on Sat, Aug 20 2016 4:06 PM
I use it for running. I don't have any issues, but only when I put the cable over my ear instead of under it. There is a sentence in the manual that gives that advice, but some of the buyers obviously don't read manuals.
I love them. Ran 13k with them multiple times, never had to put them in again as a consequence of them falling out.
Roy.
BeoVision Horizon ● BeoLab 14 Subwoofer ● B&O Play A9 ● Beolit 15 ● B&O Play H8 ● B&O Play H5
Chrisbriton
Posts 2
Thanks Roy,
There seems to be so many mixed reviews on fitting. And quite a few like yourself who have no problems at all. Can i ask how close the standard silicone/foam tips are to the charging dock when the earphones are charging? Looking at the photos they seems to be pretty close witch might make charging with a more bulky custom mouded tip a bit tricky
Page 1 of 1 (3 items) | RSS
