A young bloke in his early 20's with an expensive hobby..
Present:
Beovision 4-50 Full HD, Beosystem 3, DVD2, Beolab 8000 MK2, Beolab 7-2, Beotime alarmclock, Beosystem 2300, Beolab 2500, Beovision 8-40, Beosound 8, Beo5, Beo4 DTV
Sold:
BeoMaster 7000, BeoVox RL7000, BeoCenter 6-23 DVI, Beolab 4, B&O F1000 furniture, Beovision 8-26
I quick way to test the BeoSound 8 is to connect a device via aux line input on the rear of the unit. If the dock connector is damaged/faulty it may be that the BeoSound 8 is simply not detecting the docked product.
Opman
I had the same problem with my Beosound 8 after having it stored away a few years. There was nothing.After docking an iPod nano it showed signs of live again after a few minutes. Seems to have s.th. to do with the dock connector!?Try it with an iPod/iPhone/iPad. Via Line-in my Beosound 8 didn't react to anything.After docking/charging the iPod I can use line-in again!
