Wonder if I can make a 150Watt mono block out of one BM4400, simply using the left & right live signals and mono button pushed down?
I'll like to make a setup with one BM4400 for each MS150 (I have a lot of BM4400 on stock).
And pull out the max. power into the MS - you get the picture?
And yes of course I could easily use a BM8000 / Beolab Penta amp. for that game, but not really the same, not......
Risky business.The four channels involved would have to be very identical in performance over the whole frequency range toavoid distortion and/or damage to amplifiers and/or tweeters.One wrong move and you will have blown both channels in the Beomaster.All it takes is a flip of the Mono switch - or a drop out of a volume or balance potentiometer....And I don't think it will bring you the result you hope for anyways.A Beomaster 8000 sounds like the better solution in so many ways.
Hmm, was afraid of this answer. I'll consider something else then.The look of the 2 pcs. BM 4400 & MS 150 in the room was the mainly appreciation for this setup...
