Beosound 9000 spotify or deezer
This post has 6 Replies | 0 Followers
marexy
Posts 710
marexy Posted: Thu, Sep 1 2016 1:44 PM
Hi
Want to play spotify or deezer on my BS 9000.
So...how can i get best possible quality of soud ?
Looking for an affordable and simple solution.
Control would have to be  via android phone.
thanks
leosgonewild
Helsinki, Finland
Posts 2,373
Most affordable is a Gramofon which gives you Spotify connect.
Chromecast also work, and if you want one I will gladly see if I can throw mine all the way to where you are located.
marexy
Posts 710
marexy replied on Fri, Sep 2 2016 8:15 AM
Hi
I'm from Slovenia..so not possible.
Did check it ..and price is app 40€. ( Gramophone )
And the sound quality ...anyone has one ..try one ?
leosgonewild
Helsinki, Finland
Posts 2,373
I have it, and I think it is a good unit.
marexy
Posts 710
marexy replied on Sat, Sep 3 2016 9:07 AM
I'm trying to decide between three offers of streming receivers:
Grammophon, Soundmate, Chromecast.....
Anyone else suggests something with good ( best ) sound quality and Deezer or Spotify apps.
 I have an android phone
leosgonewild
Helsinki, Finland
Posts 2,373
Gramofon beats the chromecast in my opinion.
I would also choose Gramofon over soundmate, since the Gramofon won't drain battery from your phone.
marexy
Posts 710
marexy replied on Mon, Sep 5 2016 6:26 AM
Page 1 of 1 (7 items) | RSS
