I just moved back to America from Germany where I bought a Beo1 with the really nifty motor built in to rotate the TV, anyway I'd really like to avoid using a step up transformer and was hoping that like some other Beo products a jumper can be soldered or moved on the board to change the voltage requirements from 220v to 110v.
I don't have the model number in front of me, its the one with the speakers under the TV that come to a point in the middle and sits on the motorized rod/stand. which turns when you hit left and right on the remote
I am really handy with a soldering iron, but I can't find any diagrams anywhere, and I haven't had a chance to open her up, but I was realllllllly hoping someone out there might be able to help me.
It's a beovision 1 L. Not sure if that helps.
well ok then..
See Keith's 30 March post here: https://archivedarchivedforum2.beoworld.org/forums/t/24561.aspx
