I was using an Atlona AT-HD4-V42 with my good old beovision 8-40, until yersterday, when it literally broke the hdmi chip of the bv...
I'm now searching for a new 4x2 (or 5x2) switch that could be compatible with B&O PUC. Can anyone search on the PUC list what kind of switches are compatible? I won't go back to Atlona as its way overpriced for a switch that kills a BV after 4 years...
I may try a DVDO Quick6R, but I'm also tempted to try a cheap auto sensing switch (which may resolve the PUC compatibility issue) if I find one.
Advices please!!
diisign.com
