Beolab 20 Software Update
This post has 2 Replies | 2 Followers
Razlaw
Posts 4,345
Razlaw Posted: Mon, May 30 2016 3:19 AM
Told dealer today I was ordering a pair of 20s. I looked through the user guide and noticed that it mentions the light flashing green when a software update is being done.
As I will be connecting the speakers to a BV7-55 with cables, and not wirelessly, I assume the software updates, if any, will not occur?
I do have an Essence MK2 that is connected via the aux in to my Beosound 5. If a software update is needed, will I be able to reconfigure the system so that the 20s are connected to the Essence and in that way update the software?
Austin
United States
Posts 136
Austin replied on Wed, Sep 21 2016 10:58 PM
I had the same question about the 17s. How do you know if they need a software update or which version you are on?
Razlaw
Posts 4,345
Razlaw replied on Wed, Sep 21 2016 11:09 PM
I emailed Beocare and they told me.
Page 1 of 1 (3 items) | RSS
