Hi, I recently switched on my Avant after a couple of weeks inactivity and inputted the password. But, no picture was forthcoming, only the static screen. After investigation I found the set would not connect to the Humax STB with a scart cable, only with the three RCA cables from the connectors on the set top. All scart sockets are dead, but why? Picture isn't so good with RCA cables, and appears slightly clipped along the edges, but the dvd player still works fine.
Has a setting been lost, has something failed? Does anyone have suggestions on what I could do to restore the scart connection? Many thanks.
Dave, London
Problem solved - I needed to connect another antenna cable from the STB to the tv. Doing this rectified the problem.
