Is it possible to convert a standard Lutron Rania dimmer to a B&O Rania?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Sadly no. Bosscom (google them) is able to modify your Beo4 to send the right IR codes. It's a pcb doughterboard that you could install yourself and is almost finished in development.
I have just purchased a Beotime and wanting it to control some Lutron lights/ or other dimmers without paying a fortune. I'm guessing this cannot be converted.
I've been researching this and having looked at lots of alternatives have decided to buy a couple of these: http://www.lintronic.dk/ALUDIM.asp
although here in Denmark I have to buy them from B&O dealers (same price)
