Lost Ability to Airplay to Essence since iOS 10.0.2 Upgrade
jameseri
Posts 2
jameseri Posted: Sat, Oct 8 2016 4:17 PM
Airplay no longer pairs with the Essence since iOS update. Tried reboots and according to Beo Setup I have the latest Essence software. Any tips?
leosgonewild
Helsinki, Finland
Posts 2,373
My playmaker shows sometimes and sometimes not after with this update. Are you trying to airily from a app or from the control center? My playmaker sometimes doesn't show in the Spotify app, but usually from the control center.
jameseri
Posts 2
I can stream Spotify from my iPhone and iPad using the BeoMusic app.  I had grown accustomed to using Airplay though as most of my iTunes playlist is in ALAC format and would not play through BeoMusic. So now I am largely restricted to Spotify unless I can find an easy way to convert my ALAC tracks to a compatible hi def format for the Essence.
elephant
AU
Posts 8,219
I don't have problems Airplaying from iTunes Music to the Essence Mk II ... see bottom of photo
BeoNut since '75
L1NO
Posts 250
L1NO replied on Sun, Oct 9 2016 8:56 AM
jameseri:
Wait, what? ALAC does not play? 😑
Page 1 of 1 (5 items) | RSS
