Earset 2 question help needed!!
chris
Posts 79
chris Posted: Sun, Oct 25 2015 11:09 AM
Well i have an earset 2 that id like to use and the battery is dead...i went to a battery shop and the tiny batteries were all the wrong size. Does anyone know the type and size of the correct battery so that i can buy one??? Also having trouble finding the right plug and voltage for the charger as the original one i had got lost. Apparently even the voltage that is used for the charger is unique..i went to two electronic stores and they couldnt help me but its finding a new battery that is my main concern !!!!
Thanks and any help will be appreciated
altist
Posts 72
altist replied on Sun, Oct 25 2015 4:18 PM
Hi,When my battery needed replaced I had to order it from B&O themselves,Fitting it is a bit fiddly but I managed it with a microscrewdriver like you use for glasses.You had better brace yourself re the cost as mine was £50 a few years back but fitting it yourself may well save you a not inconsiderable sum unless you have a very generous local store.Regarding the charger they do come up for sale on Ebay for example from time to time at very reasonable cost.I hope this helps.
TWG
Posts 1,672
TWG replied on Mon, Oct 17 2016 8:20 AM
my earset 2 is dying and the battery lasts an hour max. Is the replacement battery still available? And is there a service manual for the Earset 2 available?
Page 1 of 1 (3 items) | RSS
