Hi all,
i have a beomaster 5500 that doesn't power on anymore.
With remote or manually on the right side, it displays quickly the last radio station number,
and than powers up.
How can i fix this problem ?
Thanks a lot
Zazou
Check for shorted output stage transistors and for cracked solder joints at the drivers.Check the fault detection circuit itself.
