if I do a reset in service menu, I'll wipe out ALL settings, uncluding the user ones like connections, DVB channels and such, or only the calibrations and internal, non user visible settings?
In my case, I'm referring to a BV7-40 but I do assume is the same for any TV.
It should do it, yes. After the reset the TV should be in the same state as he just left the factory in Struer. :-)
