iPhone / iPad/ iPod possible port/pin change in new models - older B&O Products
This post has 2 Replies | 2 Followers
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Fri, Jul 27 2012 10:24 AM
Apologies if this has been posted, I did try a search first.
Rumours are that Apple are going to change the charging/ docking port to different pin combinations.
http://www.iclarified.com/entry/index.php?enid=23414
Will B&O Produce anything in order to stand new products in the Beosound 8 dock or iPort? Leads are a good idea but no for a dock.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Banix
Lund, Sweden
Posts 17
Banix replied on Fri, Jul 27 2012 10:48 AM
I have also been thinking about this. Especially regarding the Beoplay A8. Since the dock is removable they could start to sell a new dock which would not change the esthetics of the speaker and one could simply swap docks depending on which device one is using.
With the Beosound 8 they could introduce an adaptor from the existing 30-pin connector to the new (19-pin?) connector and if they do not, other companies probably will (apple being one). This would however be visible...
Beolab 8000 MK II, Sennheiser HD 800
Chris Townsend
Qatar
Posts 3,531
Try this
http://www.guardian.co.uk/technology/2012/jul/24/apple-connector-iphone?newsfeed=true
There is always AirPlay!....................no wait
Page 1 of 1 (3 items) | RSS
