with the remote beo1 what command do you give to record a programme in sky tv
malcolm
malcolm welborn:with the remote beo1 what command do you give to record a programme in sky tv malcolm
w5bno123:The record command has always been Menu followed by number 8 that's providing you're using a IR version of the BR1 with older TV set.
thank you
not changed still same as beo4
