I apologize for asking this question that has most likely been answered before, but I cannot find answer.
I want to hook up a Velodyne ULD 18 powered sub to my system. I have a set of Penta2's which work fine but would like the added bass the sub can return. The sub amp has in and out jacks from the amp. Do I pull the jumper pins out of the panel and run RCA cables to and from the sub amp? If I do this, will the sub volume not be affected by the receiver volume? What have others done to solve this problem?
Thanks so much for any replies!
Thanks so much, I will try that. I'll let you know. I have been a member here for about 15 years, but have been dormant for many years. Just recently got excited again about B&O. Own a 5000 system, 5500 , 6500, and a 9000. I know that one would take care of the house, but I've been a collector! I appreciate the info.
I tried your advice, AND, it works perfectly! Thanks so much. Unfortunately, over the years I seem to have forgotten much of what I used to know about B&o info.. Really appreciate your advice and this site!
