Beocenter 2500 software
Keith
Shrewsbury
Posts 138
Keith Posted: Tue, Nov 15 2016 5:03 PM
Hi all,
I hope someone can help with this.
I have a Beocenter 2500 s/w 1.8 and hope to buy a broken Beocenter 2500 with s/w 2.0.
My question is this, I have a Beolink 7000 RDS unit with new back light and caps fitted and works like a dream.
I to make my Beocenter 2500 run a RDS unit that I have, but need to fit the software 2.0 from the broken unit.
Do I just change PCB 3  that has the microprocessor and do I need to change anything else?
Keith
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Nov 15 2016 6:46 PM
There is not much else you can change, other than the processor board :) The rest will be just the same.
But.. be aware that your BL7000 will NOT show RDS info from the BS2500, only Beomaster 7000 will send RDS info to the Beolink 7000.
You will however see RDS info in the green display on BS2500.
/Weebyx
Keith
Shrewsbury
Posts 138
Keith replied on Wed, Nov 16 2016 7:06 PM
Many thanks for your quick response Weebyx.
So not really worth doing, I had the idea that the Beolink 7000 would show the RDS information BS2500.
Thanks for putting me straight.
Cheers
Keith
Page 1 of 1 (3 items) | RSS
