Hi All I have just bought a Beovision 11 40inch of eBay and it's in amazing condition and the picture is great however I have some questions I was hoping someone could help me with
1. Do I have to use a specific B&O wall bracket ?
2. How to I get the beo remote 4 to control my SkyHD box ?
3. I thought the tv should have a slot that stored an Apple TV ?
thanks all in advance
for sky box use Thompson tv puc or Thompson hd if its hdbox, earlier models had slot for apple later models no
malcolm
m11rphy: 1. Do I have to use a specific B&O wall bracket ?
Either B&O or something from STB Brackets
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I have a BV10 on a generic flat wall bracket. I think both the 10 and 11 have a VESA complaint mount. Look to hang by weight .and not screen size
The BV11 is a beautiful TV, on mine to fit an Apple TV box in the back I needed to break some plastic internal fittings off the tv to make it fit, it broke my heart to do it but was what the dealer recommended (mind you its the 46" version). Assuming it is the same remove the large bottom left or right panel on the back and you will see a space with a plastic bar running across, this needs to be broken off and the resulting space should fit the apple TV box.
Once the covers are refitted it will not be visible. But only do this if you are confident in removing part of the case. Hopefully the description here is enough.
Use STB Brackets for the stand or wall mount, they are fantastic and its a heavy TV I wouldn't trust anything else.
Steven
