I want to control Beolab 90 with beo1 remote. IR is connected to master speaker. On remote I have done everything what is required in technical guidance for Beolab 90: setting, advanced, product, Beosound, renamed to Beolab 90. Still no response from Beo 1. Does anyone can help me? Thanks
I bought the right IR from my dealer.
I followed all his instructions but Beo 1 remote doesn’t control Beolab 90. Any other suggestions? I read in technical guide for beolab 90 that speakers must be paired with Beosound. How?
The I got from the dealer is the right
I got from the dealer the correct IR. Something I am doing wrong but can not figure it out
I thought about it but never did it . When I am home I will try and let you know. Thank you very much for your help
I tried to unplug and plug back but Beo 1 is still not working with speakers.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Thanks, I give this message to my dealer.
By the chance, do you know correct wiring?
Dealer takes all that money and can't be bothered ensuring the products work. Customer has to use beocare or beoworld. Compare that with other "luxury" brands.
Nodarkatz13844:By the chance, do you know correct wiring?
poodleboy: Dealer takes all that money and can't be bothered ensuring the products work. Customer has to use beocare or beoworld. Compare that with other "luxury" brands.
And over here anyway my closest dealer is so far away that communications are hampered by delays caused by the speed of light the distance is so great.
Jeff
Jeff: poodleboy: Dealer takes all that money and can't be bothered ensuring the products work. Customer has to use beocare or beoworld. Compare that with other "luxury" brands. And over here anyway my closest dealer is so far away that communications are hampered by delays caused by the speed of light the distance is so great.
Maybe so, but if you pulled your charge card out of your wallet I bet they could smell it from 1000km away.
Do you know how to wire correctly?
Nodarkatz13844:Razlaw 3,734 Posts OFFLINE Reply Suggest as Answer Verify Answer More Razlaw replied on 07-22-2019 5:45 PM Thank you. That is a different wiring plan than the one I followed. One I followed was same three terminals, also with two grounds on the first terminal, but different colors were indicated. I will rewire and try again. This is what I found in that link but I cannot understand how did you wired it. Can you please clarify?
I can not find the diagram. Can you please post one more time?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I tried bottom diagram and it didn’t work.
Any suggestions?
either the eye is wrong or you have the eye in the wrong socket or something else is going on where you probably need a dealer to come by. incedentally, have you fully updated them to the latest software? Could we maybe get some pictures on how it's all connected? easiest way is probably to use the app for that.
Problem is solved. Wiring was correct. The problem was that I was not finishing all instructions on Beoremote 1 . Thanks everyone for your suggestions.
