Hi All,
I am thinking of maybe getting a BS1 for the bedroom. but I have some questions:
Does the BS 1 respond to a remote, want to be able to control the lights through the MLGW?
Does it have a light that is on when not in use?
I do have an essence MK2 with a pair of beolab 4 pc (which was I won on the lovely beoworld prize draw a few years ago) which I was going into the bedroom, but am liking the brass BS1.
Toby
badgersurf: Does the BS 1 respond to a remote, want to be able to control the lights through the MLGW?
Only BT remote
badgersurf: Does it have a light that is on when not in use?
Yes. A white light unfortunately.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hi Hiort,
Thanks for the quick reply. Shame about the white light, I am not a great sleeper so the white light might be distracting, I can live with red lights!
badgersurf: Hi Hiort, Thanks for the quick reply. Shame about the white light, I am not a great sleeper so the white light might be distracting, I can live with red lights! Thanks
Same thing here.
I have suggested to the Product Manager at B&O that the light should be configurable. I.e. you should be able to choose if you want a standby light or not.
