Looked just like the old one, but had the Android system...
Nothing new.. same old same old... need to wait and se what happens with the LG versions.
/Weebyx
Weebyx:Looked just like the old one, but had the Android system... Nothing new.. same old same old... need to wait and se what happens with the LG versions. /Weebyx
vlohjr1:My only concern with the mk1 is that it does not support hdcp2.2 for all hdmi only one input
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael:You can buy a cheap adapter for that.
Specs are here: http://b-o-f.dk/sites/default/files/tech_specs_avantng_0.jpg
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Aussie Michael:Can you?
BeoGreg:I thought that with a software update last year all hdmi's (except quick panel) became 4k. I misunderstood then. A shame because with 4k tv boxes and PS4 or player you need at least two (three with my wifes 4k camera).
BeoGreg:Alright Michael, thanks for clarifying. I'm really bad at that.
No problem :)
Well one change listed in the specifications for the 55" has changed the screen from the original 'edge type backlight' to a 'direct type backlight', bringing it in line with the larger 75 and 85. I'm curious to see if this improves uneven lighting and bleed from side of the screen, particularly noticeable with darker scenes or white text against black.
@Solidsnake
Do you have a source/link for that information/the specs?
If so, it might be a good change - theoretically...
....and maybe also in real life.
@Millemissen
See my post
@Beoberg
Oh, missed that one - thanks.
It is from a dealers website - I did not find anything on the main B&O site.
