Hello, I have recently bought a Beomaster 3000-2 when i plug it in there seemed to be no power, I checked the 2 fuses and that the voltage switch was on 240 and all was fine. I opened the panels up and checked for any loose wires which all seem to be OK. i have a little electrical screw driver so tested power at the fuses and all OK i then tested power thought out the system and seem to have power running though it but no lights of sound. when switched off the power inside seems to turn off so i assume the switches work OK. I have very little knowledge on this and will greatly appreciate any advise you can offer of trying different things of how to test different problems.
Thank you
If you can measure power inside when switched on, why do you call this thread "no power" ?Lamps could have blown - that wouldn't be a first.Do you have speakers atttached?Speaker switches on?Volume a bit up?Source with a signal selected?
