Hi
Im wondering if its possible to connect a KNX/EIB Gateway through IP Tunneling while running custom strings over Ethernet. Hence: to setup both the KNX/EIB and the custom strings connector, or does one exludes the other?
Many thanks for any help
Reto
ok, I've got it finally. It works running both concurrently. The string switching on a Feller WLAN module looks like:
POST /zrap/chctrl/ch2 HTTP/1.1\0D\0AContent-Length: 6\0D\0AContent-Type: text/plain\0D\0A\0D\0Acmd=on
So you have both functions? KNX tunneling and custom strings. Thats nice.
Yep.
