Is it possible to use a beovision 4 50 full hd (not the last version with acm) without a beosystem 3 ?
I would like to give it to a friend but as he doesn't have a bs3 I wonder if he will able to use it.
I can provide him a beosystem 2 but I don't know if he will be able to plug the bv with dvi and use it in hd.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
According to another thread I need to find a panasonic remote for the model
Hello kallasr,
The bv should be a panasonic d9. i don't know if it needs a perticular panasonic remote or if any panasonic for a 50 full hd plasma would work.
If you use it with a full hd 4 50 it could be usefull to have its ref.
thanks
