BL 8000 midbass driver MK1
This post has 3 Replies | 0 Followers
marexy
Posts 710
marexy Posted: Fri, Dec 2 2016 9:15 AM
As you can see the difference is more than obvious
in all respects.
Thus, in the view as the sound.
Do not buy the first generation BL8000 MK1.
Bass sound is very very poor.
I know from experience.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Dec 2 2016 10:06 AM
Did you compare T/S parameters?
marexy
Posts 710
marexy replied on Fri, Dec 2 2016 10:54 AM
I did not
,my ears are sufficiently accurate tool for detecting differences of sound.
davidr
Montréal
Posts 172
davidr replied on Fri, Dec 2 2016 2:42 PM
Not sure of your point.
Indeed the mk.i are from 1992 probably designed in 90 or 91 and mk.ii 8002 are from mid-2000s. Beyond drivers also the amplifiers are completely different.
Anyway the 8000s and newer 18s are a sort of compromise (balance?) design; between size, SPL and bass response. Pick two.
Page 1 of 1 (4 items) | RSS
