Does anyone have a suggestion on how to connect my 2400 to a laptop PC? I looked for adapter cables to no avail. Perhaps someone knows of where I might find such an adapter.
Thank you,
Thomas Preiss
Hi Thomas, I think that Steve at Sounds Heavenly, a forum sponsor, sells exactly what you needhttp://soundsheavenly.com/bang-olufsen/67--trs-5pd-.html
Having said that, I did this years ago and used a combination of 3 things that were commonly available around me, where DIN connections are not common. So I have a DIN ->RCA cable, two barrel connectors (female RCA both ends) and then a standard PC to RCA cable.This is connected to the Tape input of the beomaster.
Thank you Ryan from Toronto. Long may Neil run.
Thomas
This one and yes tape input, or Steves cable which is guarantied to work
Thank you for the tip. I appreciate the answers to my question.
