Hi, The dvd player tray on my beovision 7 32 TV is sticking. It seems to have dropped slightly and is fouling the slide down door. If I lift it slightly with a small screwdriver it opens. Then closes OK and plays perfectly. It looks like an easy fix. How do I open things up to gain access to the mechanism? Thanks, John
