Beolink Wireless 1 Software
This post has 5 Replies | 2 Followers
bigdeniz
Posts 44
bigdeniz Posted: Sat, Dec 10 2016 6:43 PM
I have bought two Beolink Wireless 1. What is the latest Software Version and how can i check them?
Here are the SN: 2096XXXX
Thanks.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Dec 11 2016 10:58 PM
I can't recall the latest s/w version, but it is important that they both have the same version of s/w. Mine were unable to communicate with each other until I got them updated to the same s/w version. Oddly enough, one of mine used to get blown off the air every time I used the microwave in the kitchen (the one in the dining room next to it), but since I bought a new microwave after the old one died that hasn't happened.
Jeff
bigdeniz
Posts 44
bigdeniz replied on Thu, Dec 15 2016 10:25 AM
The latest Software is 2.10e
Phildlb
Posts 1
Phildlb replied on Tue, Dec 20 2016 4:31 PM
Hello, how can I get the latest software and is it difficult to install ?
thanks
Philippe
elephant
AU
Posts 8,219
elephant replied on Fri, Dec 23 2016 4:08 AM
Phildlb:
thanks
Philippe
I believe you will have to go to the dealer. At least that's what I did 8 years ago
BeoNut since '75
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Dec 23 2016 4:42 PM
That's how I got mine updated, I had to send them to the dealer, who used a dealer "tool" to update the s/w. What that tool is and how it works I have no idea, having never seen one in the flesh so to speak. Whether they had to pull the chips and put them in a EPROM burner or if they did it via a cable to one of the ports I have no idea.
Jeff
Page 1 of 1 (6 items) | RSS
