Has anyone ever successfully disassembled the beogram 1200 controls I want to take the speed and size controls off and replace with some better-looking ones but it does not seem possible to disassemble if anyone has any info on how to do this it would be greatly appreciated.
Not easy.Done from below.
Hi Martin thanks,
I have had a look and can't see anything that looks like it unscrews or anything I was just considering if the tops pop off and the there was a screw or bolt under that
it looks as tho its been riveted to the chassis
