Atlona 4K switcher hdmi
This post has 20 Replies | 2 Followers
vlohjr1
Posts 553
vlohjr1 Posted: Mon, Dec 19 2016 10:50 PM
http://atlona.com/product/at-juno-451/
Wonder if anybody have any idea whether this may be compatible with bvs esp mki avant and can be controlled by single BeoRemote ?
Vince
Michael
Sweden
Posts 2,578
Michael replied on Mon, Dec 19 2016 11:33 PM
vlohjr1:
Vince
Do you mean Avant 2014? I think it should be possible to use since it has support for Altona switches although not all configurations. However, may I ask how you wanted to use it?
vlohjr1
Posts 553
vlohjr1 replied on Mon, Dec 19 2016 11:48 PM
Hi Michael yes 2014 avant just thinking if I have 2 uhd sources Sky q and oppo 203? May be if atv has 4K in the future?
Vince
Michael
Sweden
Posts 2,578
Michael replied on Tue, Dec 20 2016 12:27 AM
vlohjr1:
Vince
Hi Vince,
The Avant 2014 has six HDMI ports. Port six (the top one) is 1080P max. But all the other ones are 4K enabled, although only HDMI 1 has HDCP 2.2 support. There are adapters to use that converts HDCP 2.2 to work on HDCP 1.4 enables sets. Effectively giving you the possibility to use modern 4K sources with the other ports. I can't vouche for it working with every source but the adapter is quite cheap (about 50 dollars per port).
Maybe that can be a solution for you? It requires power but much less than the switch I believe.
But, of course a nice thing with a switch is that you won't need several HDMI to the monitor itself.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Dec 20 2016 12:37 AM
It's unlikely anyone will know if this will be supported until it is actually released. Atlona have had this product shown as 'coming soon' for a while now...
The current solution for the scenario you describe is the use of a matrix, which has the advantage that it also splits the PUC control to each box too, but it's obviously not a cheap solution and could be described as somewhat overkill for a single beovision.
The neo matrix has been recommended by another beoworld member as working well with BeoVisions, although I've not tried it myself yet. It's pretty reasonably priced so might be a viable option too as it is probably not much more expensive than the atlona device above is likely to be sold for (although this is obviously guess work at the moment as nobody knows what the atlona switch will cost).
Martin.
vlohjr1
Posts 553
vlohjr1 replied on Tue, Dec 20 2016 12:40 AM
Thank you Michael yes I realise this but if you use the adapters you will be limited to capabilities to 1.4 rather than 2.0 i.e. 24 pfs in addition to other features
I was also hoping for a uhd br player so that I can see 4K Netflix or Amazon prime as well?
Just thoughts so that my mki can last longer.....
Vince
ssbrig
Posts 37
ssbrig replied on Tue, Dec 20 2016 1:51 AM
If you have (or will be receiving) the UDP-203 from Oppo, and you have a streaming device capable of 4k, you can plug the HDMI out from the Oppo into the Avant HDMI 2.0 (input #1) and the streaming device into the Oppo's HDMI Input to effectively have two sources capable of 4K into your Avant via the Oppo player.  Alternatively, the Altona switch will work for you.  Check with your B&O dealer for the appropriate model and installation/usage.
ssbrig
Posts 37
ssbrig replied on Tue, Dec 20 2016 1:52 AM
Michael
Sweden
Posts 2,578
Michael replied on Tue, Dec 20 2016 8:57 AM
vlohjr1:
Vince
Hi Vince, no you get full FPS!
ssbrig
Posts 37
ssbrig replied on Tue, Dec 20 2016 2:35 PM
Michael, HDMI 1.4 is not capable of outputting 60 FPS.  Vince is correct that using the HDMI ports other than number one (which is HDMI 2.0, HDCP 2.2 capable) would be a 'downgrade'
vlohjr1
Posts 553
vlohjr1 replied on Tue, Dec 20 2016 2:57 PM
Thanks for confirming that's why I was keen to use this particular switcher even though the the mki avant is not HDR but at least it is future proof for hdcp 4K content
The atlona site for bo is very good and useful for this simple switch one can probably install yourself with some help from dealers
Sandyb
Posts 2,186
Sandyb replied on Tue, Dec 20 2016 6:26 PM
I've got a Pulse Eight Neo, which seems to work pretty well from my 2-3 months spent with it......it works off Altona matrix codes, so should be effectively the same.....the Neo is fully 4K UHD capable i believe, and am running a 12-65 (main screen) and a BV14-55 (bedroom) off it......was quite a bit cheaper than the Altona option, though still not cheap......not passing through any 4K yet through the matrix, as multi room on my 4K BV14 hasnt been enabled yet, but in general seems to do its job well...........Pulse technical support are quite good at answering detailed questions......
Word of caution with matrices though, they run warm, and the internal fans will run pretty much all the time......especially 4k versions, which tend to all have internal fans, while some HD only matrices dont.......so i'd think about "lounge" conditions if putting a matrix there.....you will need to get conditions so its fan doesnt run at max speed (low / med speed is fine / manageable)....as they are noisy...which is OK with a source on, but the fans run even when the TV etc is switched off.......all do-able and depends on individual circumstances, but heat / noise can be an issue, and i spoke extensively to Altona and Pulse to understand the internal fan behaviour.......for reference i have a modest sized lounge, 20ft by (almost) 20 ft.......
in the end, happy enough with outcome, got what i wanted, a screen in each room, and just one remote in each, so first world problem solved, albeit at a cost.....
vlohjr1
Posts 553
vlohjr1 replied on Tue, Dec 20 2016 7:21 PM
Actually the one I posted is not a matrix just a 4x1 switcher but I don't know how the codes work.....
Just something for the future.....
Sandyb
Posts 2,186
Sandyb replied on Tue, Dec 20 2016 7:25 PM
my bad, sorry...
mbee
Paris, France
Posts 1,842
mbee replied on Tue, Dec 20 2016 9:39 PM
since my Atlona AT-HD4-v42 destroyed the hdmi chip of my BV8-40 (I'm currently waiting for a new mainboard), I would avoid Atlona products... I think that less expensive devices can do the same (with destruction of BV at the end or without).
so, can anyone recommend me a 4x2 switch that can be used with my BV (IR compatible via PUC), or a simple 4x2 switch which simply switches automatically to the last powered source (that would be sufficient 99% of the time if it's not PUC-compatible)
i don't need a matrix, only mirrored outputs is sufficient.
vlohjr1
Posts 553
vlohjr1 replied on Tue, Dec 20 2016 9:58 PM
mbee:
diisign.com
Don't mind me asking how did it happen?
Michael
Sweden
Posts 2,578
Michael replied on Tue, Dec 20 2016 10:18 PM
ssbrig:
Ssbrig,
I never said HDMI 1.4 I said HDCP 1.4. All five ports supports 4K 60 FPS. The only limitation is HD Copy Protection vs 1.4 instead of 2.2. For this an adapter is necessary to enable HDCP 2.2 devices on a HDMI 2.0 enabled port.
So the solution I am suggesting should work.
Here is the official information from B&O:
HDMI socket 1: HDCP 2.2, HDMI 2.0 (UHD signal with up to 60 frames per second)
• HDMI socket 2-5: HDCP 1.4, HDMI 2.0 (UHD signal with up to 60 frames per second)
• HDMI socket 6: HDCP 1.4, HDMI 1.4 (FHD only)
vlohjr1
Posts 553
vlohjr1 replied on Tue, Dec 20 2016 11:13 PM
Michael:
Ssbrig,
Hi Michael the question that I am confused is that would the converter downgrade the 60 fps to 1.4 i.e. 24/30 in addition to hdcp? If not which hdmi cables do one use in and out the converter? 2.0?
Thanks for clarifying
VinceSurprise
Michael
Sweden
Posts 2,578
Michael replied on Tue, Dec 20 2016 11:23 PM
vlohjr1:
Vince
Sure! The frame rate won't convert. The ports are HDMI 2.0 meaning they support 4K at 60 fps. BUT the HDCP 2.2 copy protection protocol was finalized later than HDMI 2.0.
The reasons for the only port one is HDCP 2.2 is probably license/cost or hardware limitation but only B&O can answer this - and they won't.
The only thing this means is that material using the newer copy protection protocol can't play back at 4K since the other ports don't know how to speak it. But with an adapter in the middle that does, this problem is fixed. When the copy protection link is OK the device will output 4K, at 60 FPS.
Exiting right? :-)
vlohjr1
Posts 553
vlohjr1 replied on Tue, Dec 20 2016 11:29 PM
Michael:
Exiting right? :-)
Thanks Michael you have saved me £££ not buying atlona (except upgrading hdmi 2.0 cables)
Much appreciated thanks Vince
Michael
Sweden
Posts 2,578
Michael replied on Wed, Dec 21 2016 9:41 AM
vlohjr1:
Smile maybe! I would recommend giving it a try. The adapter is about 50 euro in Sweden.
Page 1 of 1 (21 items) | RSS
