Hi all,
from a multiroom standpoint: is there a way to automatically group speakers in a multiroom setup? When I start playing on one device, I can add speakers via Beoplay. But I would love to automatically add all speakers when I start using one speaker. Is there a way to do that?
Example: I listen to music in the bedroom. As soon as the music starts, I want all other speakers to play the same music as well. Sonos has a similar feature that is called 'grouping' speakers.
dasun: Hi all, from a multiroom standpoint: is there a way to automatically group speakers in a multiroom setup? When I start playing on one device, I can add speakers via Beoplay. But I would love to automatically add all speakers when I start using one speaker. Is there a way to do that? Example: I listen to music in the bedroom. As soon as the music starts, I want all other speakers to play the same music as well. Sonos has a similar feature that is called 'grouping' speakers.
Please let us know more details about your setup, to understand your need.
From the Beomusic app you can activate the various linkdevices. But there is not one "button" you can press in order to activate a certain sound scene.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
My current setup is as follows:
Bedroom: V1 integrated setup with Beosound Essence (works as an alarm in the morning)
Bathroom: Beoplay A6
Hallway: Beosound 1
Living Room: Beosystem 4 with Beolab 20s, integrated setup with a Beosound Moment
Kitchen: Beovision 11
I wake up in the morning with the V1 playing radio through the Essence. I also want the A6 in the bathroom, Beosound 1 and the Beovision 11 to start simultaneously to play music. Right now, after getting up, I have to manually start the other speakers in the setup.
Different question: some devices start with a very loud volume. How can I set the volume lower, especially with the Beovision 11?
Thanks in advance!
dasun: I wake up in the morning with the V1 playing radio through the Essence. I also want the A6 in the bathroom, Beosound 1 and the Beovision 11 to start simultaneously to play music. Right now, after getting up, I have to manually start the other speakers in the setup.
You can only do that in the multiroom screen on the Beomusic app, and you need to click the "+" on the different devices you can see on the screen.
I think you need a Beolink Gateway to get the usecase covered the way you want. Then you can select e.g. "Morning" on the remote and a predefined scheme for what units shall play can be activated.
dasun: Different question: some devices start with a very loud volume. How can I set the volume lower, especially with the Beovision 11?
In the "Sound" settings in the Beovision 11, you can specify the volume to be used at startup. Remember to save settings once you have done the change.
I suppose the only way you could get the A6 and the BS1 to also play the same source is via a workaround
In the beosetup app why don't you apply a timer to both of these products - if your TV and essence is playing one source and when you turn the others on they join the ongoing music experience
When you leave the house just long press the BS1 and they will all turn off.
Aussie Michael:I suppose the only way you could get the A6 and the BS1 to also play the same source is via a workaround In the beosetup app why don't you apply a timer to both of these products - if your TV and essence is playing one source and when you turn the others on they join the ongoing music experience When you leave the house just long press the BS1 and they will all turn off.
Hiort: In the "Sound" settings in the Beovision 11, you can specify the volume to be used at startup. Remember to save settings once you have done the change.
hmm, I don't seem to find that setting. In the sound settings I only have the option to adjust the current volume and the maximum volume (as well as bass and treble). Or do I need to enter a different settings menu?
dasun:hmm, I don't seem to find that setting. In the sound settings I only have the option to adjust the current volume and the maximum volume (as well as bass and treble). Or do I need to enter a different settings menu?
