Beomaster and Beogram 5000 stopped working.
Laurence Faber
Netherlands
Posts 4
Laurence Faber Posted: Sat, Dec 17 2016 3:53 PM
Good evening Friends!
I bought a Beomaster 5000 with a Beogram 5000 about 2 years ago and they worked perfectly!
I'm a bit of a music head so my system is essentially on the whole day- if I'm at home.
Problem:
About a week ago both the Beomaster and Beogram just stopped working! I have no idea what happened or how to fix it. Both systems get power but on the Beomaster: I can't select any channels or change volume. It's as if its on standby. The orange "store" button is the only thing that does anything.
And the Beogram- if plugged in- spins the table but the buttons wont work on that either.
Please help :(
hbjorkas
Posts 7
hbjorkas replied on Sat, Dec 17 2016 4:59 PM
Can you open the front panel by pushing "open" to the left? Do you have the large MCP 5000 remote control?
Laurence Faber
Netherlands
Posts 4
I cannot open the front panel with the open button :(
And yes I have the Master control panel 5000.
Laurence Faber
Netherlands
Posts 4
hbjorkas
Posts 7
hbjorkas replied on Sat, Dec 17 2016 5:32 PM
Can you operate the unit from the MCP 5000?
My front panel "died" on one of my BM5000s, but it is still working via the MCP.
hbjorkas
Posts 7
Laurence Faber
Netherlands
Posts 4
Sadly no.
"No Transmission"  is displayed on the remote. I'm assuming thats because the system isn't on?
Theres defiantly power though because there is a small red light on the beomaster.
elephant
AU
Posts 8,219
elephant replied on Sat, Dec 17 2016 10:27 PM
Could there have been a power fluctuation ?
I suggest you power off both units for say 5 minutes.
Then power on the Master.
Then see if the MCP's transmission works.
Then check if the BM's front panel unfolds. (NB its operation is purely mechanical BTW I used to think it was motorised until I took mine apart)
Then test various buttons like the FM tuner.
Then power on the Beogram and check if it is communicating.
Good luck
BeoNut since '75
Page 1 of 1 (8 items) | RSS
